6AN8
az1
- 50...74 posty
Może pomocny będzie ten krótki tekst (niestety po angielsku, ale powinien być zrozumiały)
7199 - combination pentode/triode used as a one-tube voltage amp/phase inverter/driver for a pair of output tubes in some Ampeg amplifiers.
Note: These were once popular, but are now getting rarer and more expensive. There are a number of other pentode/triodes that can be substituted, but the pinouts are different and this will require require rewiring the socket for the tube. Examples are the 6AN8 and the 6U8. There is a Russian tube that is labeled 7199 which may work, although this is new.
Cytat pochodzi ze strony:
http://www.olga.net/dynamic/browse.php? ... ubeamp.txt
Wynikałoby z niego, można spróbować z 7199 i 6U8 (jeśli dobrze zrozumiałem intencją autora tekstu
). Spróbuj porównać parametry tych lamp.
Z pozdrowieniami od AZ1
