Maraton Z Elektrit in Bulgaria
rollingheads
10...14 postów
10...14 postów
Post autor: rollingheads »
Hello, I'm from Bulgaria.
I have radio Maraton z.
There is no such radio in Bulgaria
I advanced a lot with the restoration.
https://www.sandacite.com/forum/index.php?topic=6863.0
https://www.sandacite.com/forum/index.php?topic=6863.45
I need help for restavration.
I want to ask you for help.
The things I need to complete the restoration are:
1. Scanned copy of the high-resolution scale. To be
drawed to the "coreldraw" and printed on glass.
2. Knob dimension for drawing 3D model and printing the knob in 3D printer
3. Dimensions of the back cover to make a new one.
I suppose the things I need are the same for a maraton and a czempion.
I promise to publish the originals of the drawings.
Thanks for the help.
Best regards
Kancho Atanasov
P.P.
Later will upload photos
rollingheads
10...14 postów
10...14 postów
Re: Maraton Z Elektrit in Bulgaria
and more photo
Mirabelka
Post autor: Mirabelka »
Hi Kancho!
You can buy ready knobs here.
http://www.retrortv.com/index.html
They are copies. I buy copies for my Elektrit there.
Open the website: http://www.radioretro.pl/producenci-ele ... ja-1d6f-47
You will see what an electrite radio should look like.
Scanning the radio scale is a big problem. It is difficult to scale in good condition. Elektrit Marathon is a Polish radio, but there are very few of them in Poland.
Best regards
Andrzej
rollingheads
10...14 postów
10...14 postów
Hello,
Thanks for the site with knobs.
I wrote to them.
About the skala.
Someone with a radio should take it off and put it in a scanner.
I know it's a lot of work
But please, we'll do another marathon as a new one.
Then everyone who has the chance to print a skala.
Regarsd,
Kanho Atanasov
ECC83
Post autor: ECC83 »
In Poland brand Elektrit is very unique and desirable.
I prefer to scan the scala and put the file into the computer. In special software you should correct the photo by adding carefully missing elements.
When you have done you should search someone who can print the scale on the glass.
rollingheads
10...14 postów
10...14 postów
ECC83 pisze: pn, 27 sierpnia 2018, 09:30 I prefer to scan the scala and put the file into the computer. In special software you should correct the photo by adding carefully missing elements.
That's exactly the point.
Sometimes the meaning is lost in translation
rollingheads
10...14 postów
10...14 postów
Hello,
I still expect someone to send me a scanned copy of the original scala.
what's visible on the first picture is not for this radio.
regards.
rollingheads
10...14 postów
10...14 postów
Pleas :cry:
gustaw353
Post autor: gustaw353 »
Kol. rollingheads cały czas liczy na pomoc w zdobyciu oryginalnej skali lub jej skanu (kopii).
chrzan49
Post autor: chrzan49 »
Hi Kancho.My congratulations for restauration skills.Elektrit in really good shape are unique in Poland due war disasters.
I reccomend you contact mr Mariusz Dziubczyński in Poland who is good restorer and bulb amplifier constructor.You can find him in the net.May be he can help?
I am still busy restoring Elektrit Suprema for my friend and now it took 1,5 year.State was similar to yours but all capacitors and tuning alu capacitor were damaged by mice.Tonns of mice shit inside.Condition of patient was similar to yours.Box is now totaly restored and looks good ,alu capacitor will be produced almost new in Holland by my friend and now I must made new coils .And block capacitors of course.Each detail must be checked ,clean and polished.Loudspekar wsas full of rost but works well and trafo is probably also good.
I am not sure if scale is similar but will make scan and send you probably next week.
Wish you all the best
Tom
krzyhoo
Post autor: krzyhoo »
Mirabelka
Kiedyś pisałem do Dziubczyńskiego też w sprawie skali Elektrita. Chodziło o Czempiona. Odpisał, że postara się pomóc. Nie pomógł.
barto_s
Post autor: barto_s »
Mirabelka pisze: pn, 29 października 2018, 07:22 Kiedyś pisałem do Dziubczyńskiego też w sprawie skali Elektrita. Chodziło o Czempiona. Odpisał, że postara się pomóc. Nie pomógł.
to samo, kilka razy. Nastawiony jest raczej na sprzedaż :)
Mirabelka
Forma zdobycia skali była mi obojętna. Jakby miał na sprzedaż, a chciał sprzedać, to bym kupił. Nadal jestem chętny wymienić w moim Czempionie na ładniejszą.
Moja nie nadaje się do skanowania dla Bułgara. Poza tym jak skanuję z którejkolwiek strony wychodzi mi skan nieostry, albo z cieniami...
barto_s
Ze skanu nie wyjdzie. Lepiej odtworzyć z dobrej jakości zdjęcia
