Search Documents polish Measuring Set
Edi-MV
4 posty
4 posty
Post autor: Edi-MV »
Hello, radiofriends,
I am Edi, Restorer of historical radios and electronic Equipment.
I search Documents (schematic, adjustment, etc.) about the polish measuring set "ELPO Digital Voltmeter V 524".
V524 is a special equipment, a heavyweight electronic dinosaur. It shows the numbers 0-9 with 9 lamps !
9 numbers -> 45 lamps, additionally 5 x ".", "+" and "-"
The voltmeter is made 1971, has worked 1971- 1991 by the radiotube manufacturer "WF" in Berlin, germany, and all 52 lamps are ok !!!
Unfortunately i have problems with the counter (or shift register ?) for the last two numbers.
Who can help ???
Olaf (Edi)
Private und Band- Homepage:
http://www.greencaravan.de
Elektronik Homepage, Restauration historischer Funktechnik.
http://www.edi-mv.de
Forum:
http://www.greencaravan.de/cgi-bin/ediforum/ediforum.pl
Tiere- Homepage:
http://www.tiere-dobbertin.de
Olaf (Edi)
Forum:
Tiere- Homepage:
Bobiq
Re: Search Documents polish Measuring Set
Post autor: Bobiq »
Hello Edi,
congratulations, this is really rare and accurate measuring device. It will be hard to find any document concerning this machine.
May I ask you to post more images, showing the interior of this device?
Kind regards.
Pionier U2
Edi-MV
4 posty
4 posty
Hello, Bobic,
Yes, i can make photos, at weekend, at the time i'm at work, live afterwork in a caravan.
Edi
Olaf (Edi)
Forum:
Tiere- Homepage:
Edi-MV
4 posty
4 posty
Front View
Side View
Not Integrated Circiuts, only Germanium Transistors
Top View
The Lamp display, one lamp for every digit 0-9, one lamp for ".", and reserve lamp.
Every number has a 12- lamp- Display.
Olaf (Edi)
Forum:
Tiere- Homepage:
Edi-MV
4 posty
4 posty
Why ?
It`s a polish device... don't exist a collection of schematics of polish manufacturers, like ELPO ?
Olaf (Edi)
Forum:
Tiere- Homepage:
Post autor: fugasi »
Edi, maybe something survived, but on the other hand we know the examples of bankruptcy, razing of buildings and disappearing of any documentation. Our colleague "veturilo" (http://www.tubedevices.com/alek/pwl/pwl_e.htm) tries to gather the documentation from non-existing polish vacuum tube manufactures and it's almost like an archaeologist's job...
But you may be lucky. :)
Także i ja stałem się szczęśliwym posiadaczem tego ciekawego miernika i to około roku temu. Jednak dopiero teraz udało mi się go uruchomić. Na czulszych zakresach (0,2 i 2V) wykazuje dość dobrą zbieżność ze wskazaniami współczesnego multimetru. Na zakresach mniej czułych jest nieco gorzej. Cóż, mój egzemplarz jest z 1970r., czyli ma obecnie 48 lat. Nawiasem mówiąc Elpo produkowało woltomierz V524 od 1968 r. W środku bardzo dużo elementów zagranicznych, tzw. wsadu dewizowego. W moim egzemplarzu tu i ówdzie są polskie DMG3 czy ASY36, ale większość elementów pochodzi jednak z tzw. drugiego obszaru płatniczego. To oznacza, że w czasach swej świetności przyrząd ten musiał kosztować fortunę.
Oporniki się starzeją, może dałoby się go jeszcze lepiej wyregulować, ale do tego potrzebna byłaby jakaś instrukcja. Może ktoś ma?
Przy tej sposobności chciałbym jeszcze zapytać, czy ktoś nie ma może kabla pomiarowego do tego miernika V524?
^ToM^
Post autor: ^ToM^ »
Jakiego typu jest w tym ustrojstwie wyświetlacz?
Pzd!
Tam jest wyświetlacz projekcyjny.
