Spice modele lamp radzieckich i nie tylko
Internet to prawdziwa skarbnica lampowej wiedzy. Znalazłeś ciekawą stronę tematyczną? Tutaj możesz przekazać innym informację o jej adresie i zawartości.
witko
Post autor: witko »
pewnie już było, ale zapodam na wszelki wypadek:audioportal.su
Są tam min.:
Kod: Zaznacz cały
* 6DJ8, ECC88
* 12AX7
* 12AU7, ECC82
* 2A3
* 300B
* 12AT7, ECC81
* 6550
* EL34
* 6L6GC
* KT88
* 6AN8 -----> 6AN8T triode, 6AN8P PENTODE
* 6SN7
* 5842, 417A
* 5V4GA
* 5Y3GT
* 6D22S
* 6S33S Attention! Russian "C" means "S", "P" means "R"
* 6N7S
* 6N8S
* 6N6P
* 6N23P
* 6P3S_T Triode Mode
* 6N5P
* 6N1P
* 6S41S Attention! Russian "C" means "S", "P" means "R"
* GU50_T Triode Mode
* 6P45S_T Triode Mode
* 6N3P-E
* 6P3S	 Pentode Attention! Russian "C" means "S", "P" means "R"
* GU50 Pentode
* 6P14P_T Triode Mode
* 6R3S-1_T Triode Mode. Attention! Russian "C" means "S", "P" means "R"
* 6F5P_T Triode
* 6F5P_PT Pentode in triode mode
* 6N13S
* 6F5P	 Pentode
* EL84/6BQ5/6P14P
* 6N3P
* 6S51N-V
* 6S52N-V
* 6F12P_T Triode
* 6F12P_P Pentode
* 6P18P_P Pentode
* 6P18P_T Triode Mode
* 6E5P Tetrode
* 6N28B-V
* 6N30P-DR
* 6N27P
* 6P15P_P Pentode
* 6F3P_P Pentode
* 6F3P_T Triode
* 6F3P_PT Pentode in triode mode
* 6S19P
* 6N2P
* 6N9S
* 6E5P_T Tetrode in triode mode, R2gp=200ohm
* 6CW4
* 6P36S_T
* 6S45P-E
* 6J4 Pentode 6Ж4
* 6J4_T Pentode in triode mode
* 6P9
* 6P9_T Pentode in triode mode
* 6J32P Pentode 6Ж32П
* 6J32P_T Pentode in triode mode
* 6J9P Pentode 6Ж9П
* 6J11P Pentode 6Ж11П
* 6BR7 Pentode
* 6BR7_T Pentode in triode mode
* 6J38P Pentode 6Ж38П
* 6J38P_T Pentode in triode mode
* 6G2 Triode - Attention! This is 6Г2 triode
* 6G7 Triode - Attention! This is 6Г7 triode
* 6S4S
* 6J2P Pentode 6Ж2П
* 6J2P_T Pentode in triode mode
* 6B4G
* EF800 (EF860)
* 6L6
* E180F (~6J9P)
* 6P14P Pentode
* 30P1S_T Pentode in triode mode
* 6S7B Triode
* 5C3S
* 5C4S
* 6C5S
* 5C8S
* 6D20P
* 6X2P (diode)
* 6N17B
* 6J8 Pentode Soviet 6Ж8
* 6J8_T Pentode in triode mode
* 6J9G-V Pentode
* 6S3P
* 6P7S_T Triode mode
* 6S6B
* EC360
* ECC84
* ECC85
* EF80
* EF184
* ECF82-T (triode part, Eq. 6U
* ECF82 (pentode part, Eq. 6U8A)
* ECF82_PT (pentode in triode mode, 6U8A, TungSol data)
* EL84_T (=6P14P_T, another data, triode mode)
* 6P13S_T (triode mode)
* EL36_T (triode mode)
* 6P15P_T (triode mode)
* 6J9P_T (triode mode)
* 6J11P_T (triode mode)
* 6J52P_T (triode mode)
* 6J3P_T (triode mode)
* 6J4P_T (triode mode)
* EL861_T (triode mode)
* EL861 (Eq. E81L)
* 6J7_T (triode mode)
pozdr, wk
jackie01
Re: Spice modele lamp radzieckich i nie tylko
Post autor: jackie01 »
Czy ktoś posiada wsad z wyzej wymienionymi modelami lamp do LtSpice?
Post autor: Einherjer »
Posiada.
jackie01
Serdeczne dzięki
jackie01
Poratuje ktoś modelem ECL86 ?
